BAMBOO get commits that triggered build
andreiverdes
August 4, 2015
Hi!
Is there a way to get the git log with the commits that triggered the build from the command line inside the build agent?
I'm building an Android app with gradle and push it to Crashlytics alongside with a changelog.txt file. I would like to add those commits to a changelog.txt per build so I would know what that build is about.
PS: Sorry if I'm not offering enough details, it's my first question here laugh
6 votes
Alex Soto
If you're submitting things via a script, you can use bamboo variables to get the build's revision and get the commit log and write it to a file.
Here's an example using git:
git log ${bamboo.planRepository.previousRevision}..${bamboo.planRepository.revision} --oneline > ./commits.txt
Other bamboo variables: https://confluence.atlassian.com/display/BAMBOO/Bamboo+variables
andreiverdes
August 7, 2015
This seems to do the trick! Thanks!
shubham patni February 7, 2017
I tried following but this say "log: command not found"
gitlog=git log ${bamboo.planRepository.previousRevision}..${bamboo.planRepository.revision}
What am I doing wrong here ?
faheem.armanyous@cnb.com
June 24, 2019
The variable $bamboo.planRepository.revision  only revers to the commit hash of the default repository in the plan. not the commit that actually triggered the plan in a multiple repository plan configuration.  in my scenario the actual variable for revision is
$bamboo_planRepository_9_revision
is there a variable for the repo name or the exact commit that triggered the plan without having to figure out the repository position. ?
Davide Ceccato March 1, 2021
is there a variable for the repo name that triggered the plan ?
Same question.
Jaime S
August 5, 2015
Hi, Andrei.
I'm not sure if you can get this information from the agent within the instance, but this information is available under the 'Commits' tab in Bamboo itself in the build information, if that's helpful.
Jaime Kirch da Silveira
Atlassian Cloud Support
Any REST API for that?
