Bamboo OnDemand - Stop elastic instance rather than Terminate it
Lionel Orellana January 8, 2014
I want Bamboo to automatiically stop the elastic instance instead of terminating it. The two settings relating to this are not clear to me. First there is "Automatically terminate elastic instance when elastic agent process ends" (1) and then there is "Idle agent shutdown delay" (2) (under Automatic elastic instance management).
Is there a combination of these two settings that will make Bamboo stop the instance but not terminate it? Based on the wording I thought disabling (1) and enabling (2) would do it but the instance still got terminated.
Przemek Bruski
January 8, 2014
There's nothing in Bamboo UI that would let you do it. You can try changing the termination behaviour of your instances (e.g. through AWS Console or in the Bamboo EC2 instance setup script).
Lionel Orellana January 14, 2014
Even if I change the instance shutdown behaviour to Stop; it is still being killed by Bamboo.
lodotek
April 10, 2015
I too arrived here with the same issue.
Ondrej Medek January 26, 2016
Try AWC EC2 instance Change Termination Protection
