I've read a few questions on this forum mentioning that bitbucket isn't supported by Bamboo OnDemand, they are all a little outdated and most reference this year end of feb as the time when they are rolloing out support.
I've looked in the config and the SVN repo looks hardcoded and I certainly haven't found an easy way to configure it.
Does it support it? If not when is it likely to support it.
Simon
As per the restricted functions page, Bamboo OnDemand can only use the internal Subversion repository. You might want to keep an eye on https://studio.atlassian.com/browse/JST-4488, however.
Bamboo OnDemand has added the support for Bitbucket starting from July 2012. See: https://confluence.atlassian.com/display/AOD/July+2012#July2012-Bambooupgrade
