Bamboo build merged two builds in one
Luiz Saggioro January 14, 2019 edited
I have a bamboo plan set to 'Bitbucket Server repository triggered' and 'Branches' set to manual. My repo is configured with 'master' as being the branch and 'Enable quiet period' is not checked.
Essentially, this plan runs whenever there is a merge to master and everything works fine.
Although, I observed the following behaviour:
Branch A merges into master -> Triggers build 1
(while build 1 is running)
Branch B merges into master -> nothing appeared on the bamboo queue
Branch C merges into master -> nothing appeared on the bamboo queue
(build 1 finishes)
Build 2 starts with changes from both merges (Branch B -> master and Branch C -> master)
It doesn't seem right, since 'quiet period' is not enabled. My train of thought is that 1 change triggers 1 build.
Is it the intended behaviour or is it a bug? Maybe there is another option on bamboo to change this behaviour that I'm not aware of.
Edit 1: I'm using version 6.6.2 build 60606 - 14 Aug 18
Tom Emerson August 25, 2020
We add a unique capability for each Build Agent.  For build jobs that must be serial, a specific, unique capability requirement is added.  This breaks redundancy, should that now special build agent fail, manual intervention required to resume the pipeline.
A solution, but not optimum.
Foong
January 15, 2019
Is the Concurrent build enabled at Administration > Plans > Concurrent builds ?
If not, Branch B merges will fail to trigger a new build.
Luiz Saggioro January 15, 2019
No, it's not enabled.
Foong
January 15, 2019
Does it work fine after enabled?
Luiz Saggioro March 4, 2019
Sorry for the late reply.
My pipeline needs to be serial, so I cannot enable Concurrent builds without breaking it.
I can think of enabling Concurrent builds and limiting one agent per plan, so that I'll never have parallel builds, but would still have a build queue, but it's not scalable.
Is there any other solution to that?
Foong
March 4, 2019 edited
How about enabling Concurrent builds and dedicate a single agent to the plan?
Since the plan have a dedicated agent, only that single agent will perform build for the plan so it is still considered as serial.
Can you clarify more on the above problem?
Luiz Saggioro March 5, 2019
is the same as
The only problem is that for every plan that I need to be serial, I'll need to create one dedicated agent. It's not scalable.
e.g. If I have 10 plans, I need to set up 10 agents, each dedicated to one plan. Now, if I add X more plans, I have to create X more agents and set them to be each dedicated to one of the new plans. This is pretty annoying, specially if more than one person is in charge of this configuration.
Can't it be turned into a feature?
Like • Foong likes this
Foong
March 5, 2019
Yes, it is currently tracked as feature request here https://jira.atlassian.com/browse/BAM-8811
