I am getting the following exception when trying to pull changes from master branch. How can I fix it?
com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: com.atlassian.bamboo.repository.InvalidRepositoryException: Cannot determine head revision of 'https://bitbucket.org/.../dev' on branch 'release/3.1.2'. Branch has probably been removed.
I don't think so. The error refers to:
... on branch 'release/3.1.2'. Branch has probably been removed.
The branch 'release/3.1.2' has indeed been removed, but the repository is configured to use master branch. Why is it looking for another one?
Hi, Leandro.
Check if you're not affected by the following bug:
https://jira.atlassian.com/browse/BAM-14901
This happens when branch name and a tag short name are the same. If so, check if changing either helps.
Jaime Kirch da Silveira
Atlassian Cloud Support
Also, check these two: https://jira.atlassian.com/browse/BAM-16118 https://jira.atlassian.com/browse/BAM-12684
Time to up your Loom game! The new Loom Essentials Certification is here! Show off your skills, learn pro tips, and get officially recognized. Perfect for taking your video messaging to the next level.
