How to run a Node.js build using Bamboo OnDemand
Mark Derbecker September 28, 2013
I have a Node.js build that uses grunt. I created a plan with a task that has a requirement for Node 0.10. (This requirement caused Bamboo to exclude Windows machines as agent candidates.)
Unfortunately, when the build runs, it cannot find npm. When I SSH into the elastic instance and try to run just "node", it is not found.
Przemek Bruski
September 29, 2013
What about npm, can it find it? What if you type 'nodejs' instead of 'node'?
You can install missing packages or symlink existing binaries using instance setup script found on image configuration page.
Mark Derbecker October 5, 2013
It's not finding npm or nodejs... I'll take a look at the image configuration page
Mark Derbecker December 16, 2013
Ok, I'm back trying to get this working. I don't see where on the Image Configuration page I can do what you are suggesting.
I've also tried to get an Ubuntu instance running, because that's what we're using for development. Unfortunately that seems to just hang when it's trying to create the Elastic Agent. (I was thinking that if I could get Ubuntu running, I could execute an install script that put node and npm on the machine.)
Any suggestions would be welcome... I think I'm trying to do the simplest possible thing with Node, so surprised it's not working.
Mark Derbecker December 18, 2013
Looks like Node is not installed by default on Bamboo images.
I was able to add
apt-get update
apt-get install -y python-software-properties python g++ make
add-apt-repository -y ppa:chris-lea/node.js
apt-get update
apt-get install -y nodejs
apt-get install -y npm
to the 'Instance Startup Script' section of the 'Image Configuration' settings in Bamboo. That brought in the latest version of Node (0.10.xx).
Przemek Bruski
December 19, 2013
Node is in /opt/node-0.10 IIRC.
There will be a new, fixed Ubuntu image today or tomorrow. It will also carry a brand new node.
