Maven Test cases not getting parsed
Abhijit Patharkar
September 18, 2013
Im building a maven project which has multiple maven modules in it. A lot of modules generate JUNIT results.
But in my "Tests" section for the Maven Build task, i always see that there are "0" tests executed.
But when i see the maven build logs, i can see that there are a lot of tests executed.
Abhijit Patharkar
September 23, 2013
Thanks Robert.
Yes, i did check and they are getting generated and are in the right place. Currenlty the workaround i did was to use the Surefire HTML report plugin and generate the HTML report from the test cases and havethe HTML reports be included as artifacts.
Robert Watkins
September 23, 2013
Check to see if they are being saved to the right place. If you're using a custom sub-directory, then you need to tell Bamboo where the sub-directory is.
Get Certified! ✍️
