Plan running concurrently even with max 1 concurrent
Thomas January 17, 2019
The plan has Maximum number of concurrent builds = 1 but when using the trigger Repository pulling and Scheduled 1AM branches still build concurrently without any regard to the max number of concurrent builds being 1.
Any tips on how to reinforce this rule?
Foong
January 17, 2019
Do you mean it is a different branch plan that run at the same time?
The setting only limit concurrent build per branch plan. It does not limit the concurrent build between master plan and branch plan.
I see, thanks! Yes it was across different branches. Do you have any idea on how to limit concurrent builds per plan?
Foong
February 11, 2019
Like • Steffen Opel _Utoolity_ likes this
