Setting AWS ENI to Bamboo elastic instances
Guy Cukierman January 21, 2015
For licensing purposes I need the eth0 MAC ADDRESS to remain static on Linux Bamboo elastic instances. The way to do it (as I understand it) in AWS CLI is to use Elastic-Network-Interface, something of this kind:
aws ec2 run-instances ... --network-interfaces '[{"DeviceIndex":0,"NetworkInterfaceId":"eni-12345678"}]'
When configuring the AWS instances in Bamboo there is only option to set the VPC subnet, but I don't see an option to set the ENI, and each instance creates a new ENI with a new MAC ADDRESS.
Is there a way to solve it?
Guy.
Thanks for the quick response!
But sorry, it does not work.
Przemek Bruski
January 21, 2015
Hmm, an interesting case. Does:
ifconfig eth0 hw ether 01:02:03:04:05:06
work? You can put it into instance setup script (Administration/image configuration/Edit).
