Unknown RepositoryDefinition Error Using Build Plan Branches
Matthew Smith December 15, 2015
Hi! I'm using build plan branches for the first time, and can't get it to work. When I attempt to run a build for my branch, I get the following error. Any help is appreciated.
System Error Details
Build x.example.com - Build Serving - PROJ-1234-branch-name 1 : Plan 'XXX-XXX-1' started but a fatal error occurred
(java.lang.IllegalArgumentException : Unknown RepositoryDefinition 9994243)
Occurred: 15 Dec 2015, 7:18:31 PM
java.lang.IllegalArgumentException: Unknown RepositoryDefinition 9994243
	at com.atlassian.bamboo.v2.build.BuildChangesImpl.getBuildRepositoryChanges(BuildChangesImpl.java:213)
	at com.atlassian.bamboo.v2.build.BuildChangesImpl.setPreviousVcsRevisionKey(BuildChangesImpl.java:92)
	at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryManagerImpl.markBuildStartedNewTx(PlanVcsRevisionHistoryManagerImpl.java:60)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
	at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:98)
	at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:262)
	at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:95)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207)
	at com.sun.proxy.$Proxy138.markBuildStartedNewTx(Unknown Source)
	at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryServiceImpl$2.run(PlanVcsRevisionHistoryServiceImpl.java:53)
	at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:321)
	at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryServiceImpl.markBuildStarted(PlanVcsRevisionHistoryServiceImpl.java:48)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:313)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:224)
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92)
	at com.sun.proxy.$Proxy151.delayedStart(Unknown Source)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1$1.run(PlanExecutionManagerImpl.java:430)
	at com.atlassian.bamboo.util.CacheAwareness$2.call(CacheAwareness.java:83)
	at com.atlassian.bamboo.util.CacheAwareness$2.call(CacheAwareness.java:79)
	at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:101)
	at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:78)
	at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:118)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1.call(PlanExecutionManagerImpl.java:425)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1.call(PlanExecutionManagerImpl.java:416)
	at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:312)
	at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:85)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:801)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$400(PlanExecutionManagerImpl.java:128)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1.run(PlanExecutionManagerImpl.java:410)
	at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:49)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:31)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:20)
	at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:52)
	at java.lang.Thread.run(Thread.java:745)
rsperafico
December 16, 2015
Hello Matthew,
Thank you for your inquire.
The error above related to the fact that at certain moment there was a repository with ID 9994243 and, for some reason (i.e.: deletion) the same is no longer available to the Plan you are attempting on running. That said, please:
  1. make sure the repository exists under "Bamboo administration >> Overview >> Build resources >> Linked repositories" OR;
  2. make sure there is a Repository set up under "Plan configuration >> Repositories" tab, and the repository in question is the one you want to Source Code Checkout from
  3. make sure the same repository as above is selected under "Plan configuration >> Branches >> <YOUR_BRANCH> >> Source Repository"
  4. make sure the "Source Code Checkout" task has the repository in question selected
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
Chitrarth Sahai March 25, 2021
I am facing the same issue and I have made sure the 4 points mentioned in your answer. I removed the linked repository and added it again as well. Still facing this issue.
Is this fixed? Any workaround for this?
m
Had the same problem today with 7.1.2.
The only way I could resolve it is to run a new custom build with the same  params as the failing one (rebuilds didn't work)
Reference: https://jira.atlassian.com/browse/BAM-18309?focusedCommentId=1525576&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-1525576
Liam April 20, 2021
I am having the same issue, I am using bitbucket cloud as the repo source
Liam April 20, 2021
Ok here is the symptoms and a quicker fix:
1) build is queued
2) build is not seen in the system build queue
3) When build stopped, repo error will appear
Fix:
1) Create a linked repo with the settings but different name.
2) swap it out with the default repo for the build plan.
