Where to download a bamboo agent? And can I deploy to a remote server with this?
Mg12 June 30, 2013
Hi
The bamboo documentation is very mis-leading. I cannot see anywhere to downoad a remote agent ( see https://confluence.atlassian.com/display/BAMBOO/Bamboo+remote+agent+installation+guide?focusedCommentId=376836482#comment-376836482).
Can advise on where the download link is now?
And, can a remote agent be used to deliver a build to a remote server?
RianA
June 30, 2013
Hi there,
I am afraid it's not possible to use Bamboo OnDemand with remote agent due to its Restricted Function. You might need to use the download version in order to use it.
Hope it helps
ArmenA
July 1, 2013
Thanks for the suggestion. I have updated this page to indicate that the remote agents are available only for the Downloaded Bamboo instances - NOT for OnDemand Bamboo.
Armen
Mg12 June 30, 2013
May I suggest you make that clear in the documentation.
