×Ok so I am setting up an EC2 instance to be a Elastic agent I setup everything as per instructions then reboot the box and the it does not start, I am under the impression that the first time it runs it downloads file etc then you run a prep script and create your AMI
I get this error:
[root@ip-10-245-163-211 bamboo]# sudo systemctl status rc.local.service
● rc.local.service - /etc/systemd/system/rc.local Compatablity
Loaded: loaded (/etc/systemd/system/rc.local.service; enabled; vendor preset: disabled)
Active: active (exited) since Fri 2023-03-17 19:15:03 UTC; 7min ago
Tasks: 0 (limit: 99637)
Memory: 0B
CGroup: /system.slice/rc.local.service
Mar 17 19:15:02 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: Starting /etc/systemd/system/rc.local Compatablity...
Mar 17 19:15:02 ip-10-245-163-211.us-west-2.compute.internal rc.local[792]: Fri Mar 17 19:15:02 UTC 2023 - Started execution of Bamboo instance startup scripts, uptime: up 0 minutes
Mar 17 19:15:02 ip-10-245-163-211.us-west-2.compute.internal rc.local[799]: Fri Mar 17 19:15:02 UTC 2023 - Testing if instance has been started from Bamboo...
Mar 17 19:15:03 ip-10-245-163-211.us-west-2.compute.internal rc.local[853]: Fri Mar 17 19:15:03 UTC 2023 - This instance has not been started by Bamboo. The agent will not be started.
Mar 17 19:15:03 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: Started /etc/systemd/system/rc.local Compatablity.
Mar 17 19:21:47 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: /etc/systemd/system/rc.local.service:9: Unknown lvalue 'StanardOutput' in section 'Service'
Mar 17 19:21:47 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: /etc/systemd/system/rc.local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
Mar 17 19:22:44 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: /etc/systemd/system/rc.local.service:9: Unknown lvalue 'StanardOutput' in section 'Service'
Mar 17 19:22:44 ip-10-245-163-211.us-west-2.compute.internal systemd[1]: /etc/systemd/system/rc.local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
Hello @William Flow
Once your Elastic Instance is started, the Agent will validate the EC2 instance's metadata looking for indicators that it's been initialised by Bamboo. As you are starting the instance outside of that scope, the Agent refuses to start.
If it passes, it will then start the Tunnel listener, which will wait for a connection from the Server. Then the server will connect to the Agent and call the bootstrap process by downloading extra files from the Atlassian S3 buckets and the Bamboo Server via the tunnel.
Eduardo Alvarenga
Atlassian Support APAC
--please don't forget to Accept the answer if the reply is helpful--
I understand that I am not sure why it did not start it does a reboot and and I setup systemd so it should just start
Hello @William Flow
The Bamboo Elastic Agent will refuse to start if its EC2 instance wasn't started by the Bamboo application. Are you starting the instance through the Bamboo interface by following Administration >> Elastic Bamboo (Instances) >> Start New Elastic Instances?
Eduardo Alvarenga
