×This is a community article version of the blog post available here: https://bitbucket.org/blog/automatic-merging-when-builds-pass
Today Bitbucket is releasing a new labs feature, "Pending Merges", which allows for automatic merging of pull requests when builds pass. This means no more continually checking back in on your pull request, just waiting and waiting for your builds to pass before you can finally merge it. You will no longer be forced to begrudgingly fix that one-character whitespace typo in your comment that you really should fix, but that means you're in for another 30-60 minutes of watching your builds. Even if your builds just take 1-2 minutes, we get it. Who wants to watch builds?
This functionality works in essentially the same manner that you’d otherwise merge your pull request. When you have all required merge checks except successful builds completed, you will be able select the Merge option and we’ll take it from there.
In three pictures:
Select Merge on the open pull request.
And when all that’s remaining is passing builds…
You will be able to go ahead and request a merge of the change.
If the builds pass, we’ll go ahead and merge the change. But if they fail, we won’t merge the change and we’ll send a notification to the user that requested the merge.
This functionality works alongside merge check requirements, so branches that have required merge checks (such as a required number of approvers, all tasks being resolved, etc.) will have those checks honored. This works by preventing the option the merge if there are any open merge checks, with the exception of successful builds.
By default this functionality is not enabled on repositories, and must be enabled on each branch that wishes to grant the ability to automatically merge when builds pass.
This is selectable by repository administrators under Repository Settings -> Branch Permissions -> Edit/Add branch permission -> Allow automatic merge when builds pass.
To try Pending merges, you'll need to enable the functionality in Bitbucket labs. Pending merges is being released as a beta feature. We would love to hear your feedback before we promote the feature to all users. If you have anything to share, please click the Give feedback link under the Pending merges feature on the labs page.
Happy merging!
Brandon Reppert
31 comments
