Welcome to the next Bitbucket Pipes digest. This month comes packed with additions to Pipes. Don’t forget to subscribe (click Watch and select Articles)!
atlassian/azure-aca-deploy:0.1.1 Deploy files and directories to Azure Container Apps. |
script: - pipe: atlassian/azure-aca-deploy:0.1.1 variables: AZURE_CLIENT: $AZURE_CLIENT AZURE_CLIENT_SECRET: $AZURE_CLIENT_SECRET AZURE_TENANT_ID: $AZURE_TENANT_ID AZURE_RESOURCE_GROUP: 'my-group' AZURE_CONTAINER_APP_NAME: 'my-container' CONFIG_PATH: 'config.yaml' DEBUG: 'true'
atlassian/azure-acr-push-image:0.1.0 Pushes docker images to the Microsoft Azure Container Registry |
script: # build the image before push - docker build -t examples/my-acr-image . # use the pipe to push the image to Azure ACR - pipe: atlassian/azure-acr-push-image:0.1.0 variables: AZURE_TOKEN_NAME: $AZURE_TOKEN_NAME AZURE_TOKEN_PWD: $AZURE_TOKEN_PWD AZURE_REGISTRY: "https://myregistryname.azurecr.io" IMAGE_NAME: "examples/my-acr-image"
scribe-security/valint-pipe:0.2.1 Generate Software Bill Of Materials (SBOM) for container images, filesystems and git repositories |
script:
- pipe: scribe-security/valint-pipe:0.2.1 variables: COMMAND_NAME: bom TARGET: busybox:latest VERBOSE: 2 FORCE: "true"
atlassian/spinnaker-trigger-pipeline:0.1.2 This is a pipe to trigger pipelines in Spinnaker |
script: - pipe: atlassian/spinnaker-trigger-pipeline:0.1.2 variables: SPINNAKER_ENDPOINT: 'http://your-spinnaker.net:8084' SPINNAKER_APP_NAME: 'my-app' WEBHOOK_URL: 'http://your-spinnaker.net:8084/webhooks/webhook/demo'
wpengine/wpe-site-deploy:1.0.1 Deploy your code directly to WP Engine. |
pipelines: branches: main: - step: name: Deploy to Production script: - pipe: wpengine/wpe-site-deploy:v1 variables: WPE_SSHG_KEY_PRIVATE: $WPE_SSHG_KEY_PRIVATE WPE_ENV: '<sitename>'
atlassian/bitbucket-build-statistics:1.2.0 This pipe is used to get build minutes statistics at bitbucket repository level.
atlassian/bitbucket-upload-file:0.4.0 Deploy a file (build artifacts, build reports, etc.) from Bitbucket Pipelines to Bitbucket Downloads.
atlassian/trigger-pipeline:5.1.2 Trigger a pipeline in a Bitbucket repository.
Execute a kubectl command on your Kubernetes cluster.
Find, fix and monitor known vulnerabilities in your app dependencies and docker image.
atlassian/google-app-engine-deploy:1.2.0 Deploy an application to Google App Engine.
atlassian/jira-create-issue:0.3.1 With this pipe you can create a JIRA issue from a Bitbucket Pipeline
atlassian/aws-cloudformation-deploy:0.16.0 Deploy your stack configuration template to AWS CloudFormation
This is a pipe to fetch secrets from a HashiCorp vault
42crunch/api-security-audit:3.4.0 The pipe performs a static REST API analysis of your OpenAPI (Swagger) files, and uses more than 200 checks on best practices and potential vulnerabilities to ensure their quality and security.
atlassian/azure-storage-deploy:1.1.0 Deploy files and directories to Azure Storage.
atlassian/datadog-send-event:2.0.2 Send an event to Datadog.
atlassian/opsgenie-send-alert:1.0.1 Sends alert to Opsgenie
atlassian/bitbucket-pipe-release:5.3.2 Release a Bitbucket Pipe
Deploy to Amazon S3.
Deploys your code to a remote server via the FTP protocol
atlassian/bitbucket-clear-cache:3.3.0 This pipe allows you to clear Bitbucket Pipelines caches
atlassian/aws-lambda-deploy:1.8.2 Deploy function to AWS Lambda.
jcountsnr/newrelic_observability_event:0.0.7 Send an event to New Relic.
To discover more pipes, visit our Bitbucket Pipes Marketplace.
If you’d like to suggest a pipe to be improved or new pipe to be implemented, please, find the appropriate ticket in the list of existing tickets , vote for them or create a new suggestion request with type Suggestion and Component: Pipelines - Pipes.
If you’d like help with Bitbucket Pipes, or you have an issue or feature request, let us know on Community.
Oleksandr Kyrdan
0 comments
