Bitbucket Pipes digest: November 2020
Pipes monthly digest November 2020
Welcome to the next Bitbucket Pipes digest. This month comes packed with additions to Pipes. Don’t forget to subscribe (click Watch and select Articles)!
New pipes
jira-create-issue
atlassian/jira-create-issue:0.1.1
Create a Jira issue from a Bitbucket Pipeline
script:
- pipe: atlassian/jira-create-issue:0.1.1
variables:
JIRA_BASE_URL: $JIRA_BASE_URL
JIRA_USER_EMAIL: $JIRA_USER_EMAIL
JIRA_API_TOKEN: $JIRA_API_TOKEN
JIRA_PROJECT: "PROJ"
JIRA_ISSUE_SUMMARY: "This is a sample issue summary"
Updated pipes
azure-aks-deploy
atlassian/azure-aks-deploy:1.0.0
Deploy a containerized application to AWS ECS
Changes:
aws-ecs-deploy
atlassian/aws-ecs-deploy:1.3.0
Changes:
  • Add support for the FORCE_NEW_DEPLOYMENT variable. Use this option
    if you need to trigger a new deployment with no service definition changes:
    if your updated Docker image uses the same tag as what is in the existing task
    definition for your service (for example, my_image:latest).
snyk-scan
snyk/snyk-scan:0.4.6
The pipe uses Snyk to find, fix and monitor known vulnerabilities in your app dependencies and docker image.
Changes:
  • Fix docker configuration
  • Fix DOCKER_HOST config
firebase-deploy
atlassian/firebase-deploy:0.7.0
Deploy your code to Firebase
Changes:
  • Update NodeJS version to 12 lts in the Docker image.
  • Update firebase-tools version to the 8.14.1.
  • Add support for flexible NodeJS LTS verions.
google-gke-kubectl-run
atlassian/google-gke-kubectl-run:1.3.1
Run a command against a Google Kubernetes Engine cluster. This pipe uses kubectl, a command line interface for running commands against Kubernetes clusters.
Changes:
  • Update dependency kubectl to 1.19.3 version.
aws-lambda-deploy
atlassian/aws-lambda-deploy:0.5.7
Update Lambda function code and create new version, and create/update aliases pointing to versions.
Changes:
  • Bugfix: enabling debug.
To discover more pipes, visit our Bitbucket Pipes Marketplace.
Top Community questions
If you’d like help with Bitbucket Pipes, or you have an issue or feature request, let us know on Community.
1 comment
PrivacyIsARight
November 19, 2020
What happened to the memory metrics in bitbucket-pipelines? They're gone.
Like Charlie likes this
