How to remove a commit from Atlassian Bitbucket
Hello!
In this article I will show you how to delete a commit from a Bitbucket repository.
Why would we need to delete a commit?
It can happen if you accidentally pushed sensitive information into your Bitbucket repository.
For example, you forgot to exclude a file with passwords from adding to git or you provided your password in one of the source files to test how the program works and then you forgot to remove your password from this source file. You pushed commits from your local repo to your Bitbucket repo and that is it. Your sensitive information is there. Everyone with access to this repository can see your password, for example. How to remove this sensitive information?
You can delete your repository and create a new one. But it would make you apply all settings from the deleted repo back and warn your mates, that you created a new repo. It sounds too complicated.
A simpler way would be to remove the wrong commit.
In this tutorial I will show you step by step how to do it.
Create a Bitbucket repo
First I will create a Bitbucket repository:
Create a local repository, make changes, push to Bitbucket
I will create a new folder for my repository:
mkdir bitbucket-tutorial
cd bitbucket-tutorial/
I will initialise the git repository and add the remote for my Bitbucket repository:
git init
git remote add origin https://alex1mmm@bitbucket.org/alex1mmm/bitbucket-repo-article.git
I will create a new file and add some contents:
touch mynewfile.txt
Here is the contents of mynewfile.txt:
this line is initial commit
I will commit the changes and push the changes into Bibucket:
git add *
git commit -m "initial"
git push origin master
I will make changes to mynewfile.txt:
I added my password info here
I will commit changes and push to Bitbucket:
git add *
git commit -m "sensitive info"
If we have a look at our Bitbucket now we will see two commits:
And our commit with sensitive information contains our password line:
Even if we remove our password from mynewfile.txt, commit changes and push to Bitbucket, we will still be able to see our commit with sensitive info and hence our password.
We need to remove this commit completely from our Bitbucket repo
Remove commit with password
Let's first find the id of our commit:
git log --oneline --graph --decorate
Here is the output:
I marked the id of our commit with a red rectangle.
Now let's remove this commit. We need to reset our git repository to the commit which took place before our wrong commit. The id of the previous comment is 3e90065:
Now let's reset our repository
git reset --hard 3e90065
Now mytextfile.txt looks like this:
Correct! We do not have our information about the password.
Our commit history looks like this:
We do not have our comment with sensitive information. Also correct!
But if we look at our Bitbucket repository, we still have our sensitive info comment:
That is because we did not push our changes form our local repository to our Bitbucket repository. Let's do it:
git push --force origin master
And now if you have a look at our repository in Bitbucket we will have only our initial commit:
Success! We removed the commit with our password from our Bitbucket repository.
18 comments
Kirill
July 28, 2020
Thank you very much for a very clear explanation!
Anthony Uk
October 14, 2020
I tried this on our Bitbucket and it did not truly work.
Although the commit disappears from the list, if you know the commit ID you can still look at it and see the password file by manually entering the URL.
Like # people like this
Dariusz
February 18, 2021
Simple explanation, great result !!! THX
KamyFC
March 9, 2021
Thanks this worked. I had to get rid of a rouge commit from a rogue dev!
eric-914
September 3, 2021
Will this work if the commit in question is not the last, most recent commit?
Christian Avila
will this work if the commit in question is not the last one?
innovatesol7
December 13, 2021
Hi, this worked great to rewind back several commits, just add in any id in the reset command (see below) - the id does not have to be the last one (to answer previous questions above) :)
git reset --hard <commit id here>
michael_glenn_williams February 7, 2022
What if you created the commit using the Bitbucket website? Can we delete it without having to pull it down to a local and delete it using the local CLI ?
Like Lonnie likes this
Mohamed Hussein
February 24, 2022
Thank You, it worked with me
abreton
March 14, 2022
Biggest issue is that if you know the commit's URL, you will still be able to access all the information, even after removing said commit and force pushing.
MrAtheist
June 16, 2022
This definitely doesnt work in a PR since it would show all the commit trail... which i dont think github does this at all
Bhavesh Prajapati
November 2, 2022
Thank you it is very useful for all.
why use --force ?
AfrozBasha Arab January 2, 2023
@Alexey Matveev  it was good but a easy one.
what if the sensitive information was in the initial commit ?
my use case has sensitive information in the very first commit and there are lot of commits happened on that, now I want to remove the sensitive information from the first commit.
Please help me on this
Patrick Nelson
A simple force-push doesn't seem to really kill commits like these (at least not immediately).
I found a commit with credentials in it so I was forced to fix it. After force-pushing my rebase/rewrite to each of the affected branches, I double checked the offending original commit has to make absolutely sure that it was removed, but alas... that's not really the case. I figured that might happen because, even locally, you still have to garbage collect to remove "unreachable" commits like these, e.g.:
git reflog expire --expire-unreachable=now --all
git gc --prune=now
However, if you go directly to the commit hash URL in Bitbucket it still shows with this banner which tells me that it needs to be garbage collected on Bitbucket's side. Does that happen? Oh lordy I hope so...
This commit is unreachable from any branch or tag in this repository. It may be from a fork outside of this repository.
Like Martin PIRON likes this
Kuldeep Chaudhary
February 27, 2023
This worked but what for overview page there i can see he changes like in this SS i removed 'second commit' but it is appearing as a activity and changes can also be found. Is there any way to remove completely and no activity appears?
Steffen Schreiber
May 5, 2023
@Bhavesh Prajapati
If you remove a commit which was commited already, the chain of predecessor and successor commit (id) (or HEAD) would be invalid. This "-f"/"--force" will trigger a rebase of your targeted branch.
Steffen Schreiber
May 5, 2023
If you want to remove serveral commits which are not your latest ones you case use the (interactive) rebase:
$ git rebase -i HEAD~20
Use this to modify one/multiple/all last 20 commits.
$ git rebase -i <commit-id>
Use this to modify one/multiple/all back until this commit.
The '-i' will open your default git editor (by default Vim) and will list you all relevant commits. For the use case that you want to delete a commit, replace the "pick" prefix with a "drop" in front of the specific commit id at your listing. Then save the listing and push it to your remote repository using the '--force' argument as decribed by @Alexey Matveev.
Phil Slawson
August 29, 2023
be careful using this with branches.  It made a complete mess of my repository.  I commited to the wrong branch, and realized I needed to roll that one back.  First, I commited my changes to the correct branch, then I went back to the original branch, and attempted to use these commands to fix it.  Now the head of both branches are in the same, hodgepodge state with some files at the former commit, and some at the most recent (which was supposed to be deleted).  Lost a bunch of work.
