The grace period for Bitbucket Cloud 'create repository' and ‘auto-assign’ permissions, deprecated when we released Project Permissions in March, is ending on October 30, 2023.
'Create repository' and 'auto-assign' permissions were originally designed to serve a flat collection of repositories with no true hierarchy or segmentation. Project permissions established a hierarchical structure of workspace > project > repository, which provides a means for permission inheritance and the ability to segment development teams.
After October 30, workspace admins will no longer be able to assign groups the 'create repository' permission across the entire workspace. Going forward groups may only be assigned the permission to create new repositories within the project.
Similarly, after October 30, groups can no longer be assigned new default permissions on newly created repositories. Instead, groups will inherit permissions from the project or can be assigned permissions explicitly on newly created repositories.
No action is needed for now. All 'create repository' and 'auto-assign' permission assignments will continue to work on October 31 exactly the same as they do today. Your users will experience no disruption.
We are removing the ability to configure new instances of permissions but are not removing any existing configurations. All of the permissions you have assigned to your users will remain in place for now. Customers are encouraged to transition to project permissions as soon as they can but will not be forced to adjust overnight.
Existing 'create repository' and 'auto-assign' permissions can be removed from groups but they cannot modified. Once removed from a group, these permissions cannot be reapplied to a group.
'Create repository' and 'auto-assign' permissions were intended to automate and scale permission assignment across a flat group of repositories but they are not fully compatible with a compartmentalized project hierarchy. Therefore, there is not a direct analog for these legacy features so adjustments are necessary.
Create Repositories
We have not removed this permission entirely but moved it under the project administration. This provides more autonomy for projects and allows more users the ability to create repositories without granting them access to other projects.
Groups of users can also now be granted the permission to create new projects in your workspace and manage that project independently of projects and repositories they should not be able to access.
Workspace admins may also create projects for each user to create or fork repositories to work on independently or with teammates.
Auto-Assign Permissions
Rather than explicitly adding new permissions automatically to every new repository upon creation, permissions are now implicitly inherited for all repositories (new and old) from the project. Permissions set on the project never need to be set for an individual repository.
Permission assignment on repositories may also be automated via the Bitbucket Cloud API.
curl --request PUT \
--url 'https://api.bitbucket.org/2.0/repositories/{workspace}/{repo_slug}/permissions-config/groups/{group_slug}' \
--header 'Authorization: Bearer <access_token>' \
--header 'Accept: application/json' \
--header 'Content-Type: application/json' \
--data '{
"permission": "read"
No groups created after October 30, 2023 can be assigned either the 'create repository' or an auto-assign permission. Those options will no longer be available for newly created groups.
When an existing group - created prior to October 30 - is modified to remove either the 'create repository' or an auto-assign permission that permission will be removed permanently and cannot be reapplied. After confirming the removal of these permission configurations from a group, they will be permanently removed from that group..
Over the next 12-18 months, when a workspace is integrated with our new Unified User Management within Atlassian Admin all deprecated permissions will be removed.
Patrick Wolf - Atlassian
Product Manager
Atlassian
3 accepted answers
5 comments
