Hi everyone - This RFC is to gather ideas/feedback on our planned implementation for a Docker Image Registry feature for Bitbucket Cloud, a new feature coming later this year. This feature aims to enable users to publish, manage, and consume Docker images directly within Bitbucket Cloud.
Although initially limited just to Docker/OCI images, this functionality will eventually be expanded to support common library/package registries as well.
We are particularly interested in your thoughts on the permissions/access model associated with this feature. Your insights will be invaluable in helping us refine this functionality to better align with your workflows
Motivation
Currently, Bitbucket users rely on external package management solutions for Docker images and other types of packages which introduces several challenges:
Developers must switch between Bitbucket and external tools, reducing productivity
Permissions must be managed separately in external systems, leading to inconsistencies and potential security risks
The Docker Image Registry will integrate directly into Bitbucket Cloud at the workspace level, providing a centralized hub for managing Docker images. While the image registry exists at the workspace level (one namespace per workspace), images will be linked to specific repositories and inherit the repositories permissions by default, with options for administrators to customize access to individual images as needed.
The registry will operate at the workspace level, with images linked to individual repositories. Permissions will align with existing repository roles (Admin, Write, Read), though image admins can override these settings where necessary. Below are the key use cases:
Creating a New Image
Role: Image Admin (Repository admin permission)
Description: Responsible for publishing a new Docker image to the registry for the first time - or creating the required record in Bitbucket Cloud to map an image name to a repository, so another user (with write permissions) can push the first version of the image.
Pushing a New Version of an Existing Image
Role: Image Publisher (Repository write permission)
Description: Can push updates or new versions of an existing image. Can push the initial version of an image if a record has already been created in Bitbucket to map the image name to a repository where the user has write permissions.
Consuming an Existing Image
Role: Image Consumer (Repository read permission)
Description: Can pull and use already published images from the registry.
Note: It will be possible for Image Admins to also mark individual images as “Public”, making them consumable to any user in the workspace without granting users read permissions on the repository the image is linked to.
Editing Image Settings
Description: Can adjust image permissions, such as making an image accessible to everyone in the workspace (read-only).
After extensive research of alternative/competitor solutions, we settled on this proposed model for a number of reasons.
We want to be able to utilise the existing functionality we have in the repo/project hierarchy to infer or create ergonomic permissions structures, something only possible if Images are explicitly linked to a particular repository.
For example, we may want to allow customers to grant certain Pipelines deployment environments implicit write permissions to images linked to the repo that environment is part of, allowing Pipelines to publish image updates without requiring any kind of tokens to be managed or passed to Pipelines by a user.
We also want to make sure customers can utilise their existing user/group permissions structures to manage access to images (especially if those groups are managed via an external IDP), rather than having to create an entire parallel permissions structure just for images.
Some competitors allow customers to create multiple registries, either at the “workspace” (equivalent) level, OR at the “repository” (equivalent) level, or both. From our testing and personal experience, this can be extremely cumbersome to manage and administer, and creates extremely complex and problematic security/permissions constructs.
Some solutions allow any user to push the initial version of an image to the global registry, before then associating it with a repository later. From our testing and personal experience, this can cause issues for registry management and also complexities in permissions models. It results in one of the following undesired scenarios:
Any user can push an image to the global registry, but then a Workspace administrator is required to come along and associate that new image to a repository in order for permissions to be applied.
This places extensive effort on the Workspace admin.
It also creates a large risk of “orphaned” images clogging up the registry.
Any user can push an an image to the global registry, and that same user takes “ownership” of that image, and can then associate it with a repository later.
This doubles the complexity of the overall permissions model as images must now support two parallel permissions schemes. One based on individual user ownership, and the other based on the existing repository based permissions model.
It also introduces questions/complexities around the fact that users would only be able to link images to repos they have admin permission over - meaning a repo admin must still be involved in the process anyway.
It introduces the same risk of “orphaned” images clogging up the registry.
We’d love your thoughts on the proposed permissions model:
What are your views on the baseline assumption of attaching images stored in Bitbucket Cloud to repositories existing within the system?
Does this approach align with your current workflows?
Are there existing structures/capabilities tied to the repository that you would like to see integrated with an image registry?
Are there situations you would not want this to be the baseline structure?
What are your views on the baseline assumption of inheriting permissions from the existing Bitbucket permissions structure?
Are there any specific use cases where these structures would not work for your workflows or use-cases.
Your feedback will be crucial in refining this feature to ensure it aligns with customer requirements. Let us know what you think in the comments section below.
Hamreet Kaur
Associate Product Manager - Bitbucket Cloud
Atlassian
12 comments
