Sign up Log in
A proper merge commit....how to do within a PR?
David V_ Corbin July 25, 2022
How to do TRUE merge as part of a PR (meaning a new merge commit that has 2 - or more parents). Not a FF (that makes it look like work was done "on" the target branch); not a Squash (that eliminates the history)....
Patrik S
August 2, 2022
Hello @David V_ Corbin ,
Thank you for reaching out to Atlassian Community.
When you click the "Merge" button in a pull request, a new panel will be displayed with an option to choose which merge strategy you'd like to use :
The currently available option are Merge commit, squad, or Fast forward. Accordingly to your description, the option that would create a new commit with two parents would be Merge commit.
You can also set the default merge strategy in a given repository by going to Repository Settings > Merge Strategies.
Hope that helps! Let me know in case you have any questions.
Thank you, @David V_ Corbin .
Patrik S
Ulrich Kuhnhardt _IzymesCo_
Hello David,
to override the merge-commit message Bitbucket creates you can trigger a PR merge via the Bitbucket cloud rest api https://developer.atlassian.com/cloud/bitbucket/rest/api-group-pullrequests/#api-repositories-workspace-repo-slug-pullrequests-pull-request-id-merge-post and define the merge message via the 'message' request parameter.
Hope that helps
Ulrich
// Izymes
