Add bitbucket repository as dependency of a project with ssh
Jérôme Legrand
January 25, 2020 edited
I'm trying to add a repository from bitbucket with ssh to a project.
With the following package.json, I had an error with the last dependency.
"dependencies": {
"githuHTTPS": "https://jeromelegrand@bitbucket.org/jeromelegrand/test.git",
"githubSSH": "git+ssh://git@github.com:jeromelegrand/test.git",
"bitbucketHTTPS": "https://git@bitbucket.org/jeromelegrand/test.git",
"bitbucketSSH": "git+ssh://git@bitbucket.org:jeromelegrand/test.git"
 With YARN :
[1/4] 🔍 Resolving packages...
error Command failed.
Exit code: 1
Command: git
Arguments: archive --remote=git@bitbucket.org:jeromelegrand/test.git refs/heads/master package.json
Directory: /Users/jeromelegrand/test
Output:
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
With NPM:
npm ERR! premature close
npm ERR! A complete log of this run can be found in:
npm ERR! /Users/jeromelegrand/.npm/_logs/2020-01-25T13_11_55_287Z-debug.log
The log file :
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'i' ]
2 info using npm@6.12.1
3 info using node@v12.13.1
4 verbose npm-session 56f0567f3a5243c0
5 silly install runPreinstallTopLevelLifecycles
6 silly preinstall test
7 info lifecycle @~preinstall: @
8 silly install loadCurrentTree
9 silly install readLocalPackageData
10 timing stage:loadCurrentTree Completed in 8ms
11 silly install loadIdealTree
12 silly install cloneCurrentTreeToIdealTree
13 timing stage:loadIdealTree:cloneCurrentTree Completed in 0ms
14 silly install loadShrinkwrap
15 timing stage:loadIdealTree:loadShrinkwrap Completed in 2ms
16 silly install loadAllDepsIntoIdealTree
17 silly fetchPackageMetaData error for bitbucketHTTPS@git+https://git@bitbucket.org/jeromelegrand/test.git premature close
18 silly fetchPackageMetaData error for githuHTTPS@git+https://jeromelegrand@bitbucket.org/jeromelegrand/test.git premature close
19 silly fetchPackageMetaData error for githubSSH@git+ssh://git@github.com/jeromelegrand/test.git premature close
20 silly fetchPackageMetaData error for bitbucketSSH@git+ssh://git@bitbucket.org/jeromelegrand/test.git premature close
21 timing stage:rollbackFailedOptional Completed in 0ms
22 timing stage:runTopLevelLifecycles Completed in 3002ms
23 silly saveTree test
24 verbose stack Error: premature close
24 verbose stack at PassThrough.onclose (/usr/local/lib/node_modules/npm/node_modules/end-of-stream/index.js:47:67)
24 verbose stack at PassThrough.emit (events.js:215:7)
24 verbose stack at emitCloseNT (internal/streams/destroy.js:69:8)
24 verbose stack at processTicksAndRejections (internal/process/task_queues.js:79:21)
25 verbose cwd /Users/jeromelegrand/test
26 verbose Darwin 19.2.0
27 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "i"
28 verbose node v12.13.1
29 verbose npm v6.12.1
30 error premature close
31 verbose exit [ 1, true ]
If I remove the last dependency, I had no error with YARN only.
"dependencies": {
 With NPM, it never works.
Whith YARN and GITHIUB it works with HTTPS and SSH, but with BITBUCKET it only works with HTTPS.
I need to use BITBUCKET over SSH so, someone can help me ?
Thanks.
