Hello, i just try to use azure interactive login for helm deployment and package errors with following errors:
Switched to context "aks".
kubelogin convert-kubeconfig -l spn
//common.sh: line 108: kubelogin: command not found
helm ver v3.5.4
helm cmd upgrade
...and later...
kubelogin is not installed which is required to connect to AAD enabled cluster.
A new pipe's version with updates and fix is released:
atlassian/azure-aks-helm-deploy:3.2.0
with the next updates:
bump mcr.microsoft.com/azure-cli:2.56.0
bump and pin kubernetes v1.29
add kubelogin v0.1.0
Best regards,
Oleksandr Kyrdan
Hi @michal.koval . We will investigate this and notify you.
Regards, Igor
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
