Bamboo connection to Bitbucket Cloud - Test connection failing
Jon Starbird
May 31, 2019
I am setting up Bamboo to connect to our Bitbucket Cloud instance and everything works up until I click Test Connection.
So I can connect, select a Repo, select a Branch all fine.
Then I click Test Connection and it just says:
"We couldn't connect to the repository. The details you provided were invalid."
I have tried both SSH and username/password and it just keeps giving the same message.
Bamboo's logs are not showing anything so not to sure what is going on here.
Any suggestions??
2 accepted
Jon Starbird
June 5, 2019
As someone else might hit this I wanted to update what was the final solution.
After getting an update for Bamboo that was fixing an issue with BitBucket Cloud connnections which did not fix our issue I reached out to Atlassian support and they helped find the issue.
It turned out that the Temp folder used by Git via Bamboo was under the install folder of Bamboo itself. This is on Windows and the person who installed it had put it under Program Files and the Space there was causing a problem.
I ended up having to change the JVM setting for the tmp folder:
-Djava.io.tmpdir=<some path without spaces>
Jon Starbird
May 31, 2019
