I think this is a bug with the Bitbucket API.
I triggered a pipeline build with a curl like:
curl \
-X POST \
-s \
--fail-with-body \
--user blah:blah \
-H 'Content-Type: application/json' \
https://api.bitbucket.org/2.0/repositories/blah/some-project/pipelines/ \
-d '{...}'
...and it triggered fine. The response includes this fragment:
"links": {
"self": {
"href": "https://bitbucket-pipelines.prod.public.atl-paas.net//rest/1.0/accounts/zzzz897f-cf32-4b66-825f-5123a9665fab}/repositories/zzzzf159-d03c-4508-a9cb-fa5a922e7e07}/pipelines/zzzz4283-b506-43eb-a8b5-376806f99be6}"
"steps": {
"href": "https://bitbucket-pipelines.prod.public.atl-paas.net//rest/1.0/accounts/zzzz897f-cf32-4b66-825f-5123a9665fab}/repositories/zzzzf159-d03c-4508-a9cb-fa5a922e7e07}/pipelines/zzzz4283-b506-43eb-a8b5-376806f99be6}/steps"
...but when I tried to GET either of those URLs, I get a 404. When I remove the double slash at the end of the hostname (`paas.net//rest`), then I get a better response. I actually get a 401, but that probably is something I'm doing wrong.
The point is that the server probably has a trailing slash configured on the prefix that is prepended to the rest of the URL that's returned to the caller.
Hi Tom,
This is indeed a bug, the urls that are returned are internal urls and cannot be used to retrieve the pipeline or the steps.
We have a bug report about this in our issue tracker:
https://jira.atlassian.com/browse/BCLOUD-21062
The way to work around this at the moment would be to manually assemble the url instead of using the ones in the response
https://api.bitbucket.org/2.0/repositories/{workspace}/{repo_slug}/pipelines/{pipeline_uuid}
https://api.bitbucket.org/2.0/repositories/{workspace}/{repo_slug}/pipelines/{pipeline_uuid}/steps/
Theodora
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
