Bitbucket + DAST tools
Admin Admin February 14, 2022
hello,
 what DAST tools are integrated with the Bitbucket pipelines?
Mark C
February 17, 2022
Hi @Admin Admin
Thank you for reaching out to the community.
You can actually use any of your preferred tools in Pipelines as long as it is installed in a Docker image you used or it is containerized Docker where you can run it within the Pipelines step container.
When it comes to a DAST tool that can integrate with Bitbucket Cloud, we recently partnered with Snyk in order to implement a security-first mindset when it comes to your repositories.
You can check out this blog post for more information and explore Snyk integration with Bitbucket Cloud Pipelines at the same time. - https://bitbucket.org/blog/security-code-scanning
Hope it helps and let me know if you have further questions.
Mark C
