Hi all, I'm building a docker pipeline for my project to be deployed on Google Clould Services based on this example. On my Dockerfile I have to build some gems which are hosted on my private repository on bitbucket. However, during the build step, the Docker container generated by the Pipeline can't see my SSH keys saved on my repository.
My question is how can I send the SSH keys configured on the pipeline to be used during by my container?
bitbucket-pipelines.yml:
At the #BUILD IMAGE comment I can get the private SSH correctly configured on my repo
options:
docker: true
pipelines:
default:
- step:
name: Deploy to Container Registry
image: google/cloud-sdk:latest
caches:
- docker
script:
- export PRIVATE_KEY=`cat /opt/atlassian/pipelines/agent/data/id_rsa`
- export IMAGE_NAME=gcr.io/$GOOGLE_PROJECT/$GCLOUD_REPO_SLUG:$BITBUCKET_COMMIT
- export ENVIRONMENT=staging
- echo $GOOGLE_CREDENTIALS | base64 -d > ~/.gcloud-api-key.json
- gcloud auth activate-service-account --key-file ~/.gcloud-api-key.json
- gcloud config set project $GOOGLE_PROJECT
- gcloud container clusters get-credentials $GOOGLE_CLUSTER --region=$GOOGLE_REGION --project $GOOGLE_PROJECT
- gcloud auth configure-docker --quiet
# BUILD IMAGE
- docker build -t $IMAGE_NAME --build-arg SSH_PRIVATE_KEY="$PRIVATE_KEY" .
# PUBLISH IMAGE
- docker push $IMAGE_NAME
Dockerfile:
FROM ruby:2.5.1-alpine3.7
ARG SSH_PRIVATE_KEY
RUN \
echo "http://dl-cdn.alpinelinux.org/alpine/edge/community" >> /etc/apk/repositories \
&& apk update && apk upgrade \
&& apk add bash build-base libxml2-dev libxslt-dev openssh-client git
&& apk upgrade --available \
&& rm -rf /var/cache/apk/* \
&& mkdir /usr/app \
mkdir /root/.ssh/ \
&& echo "${SSH_PRIVATE_KEY}" > /root/.ssh/id_rsa \
&& eval $(ssh-agent -s) \
&& chmod 600 /root/.ssh/id_rsa \
&& ssh-add ~/.ssh/id_rsa \
&& touch /root/.ssh/known_hosts \
&& ssh-keyscan bitbucket.org > /root/.ssh/known_hosts
# This line fails with# RUN ssh-add /root/.ssh/id_rsa
---> Running in 9d6b522d6355
Could
# not open a connection to your authentication agent.
The command
# '/bin/sh -c ssh-add /root/.ssh/id_rsa' returned a non-zero
# code: 2
WORKDIR /usr/app
COPY Gemfile /usr/app/
COPY Gemfile.lock /usr/app/
RUN bundle config build.nokogiri --use-system-libraries \
&& bundle install
OBS: I can do an ugly alternative solution which is generating a new key and overwriting the new key with the value from the args (SSH_PRIVATE_KEY). But this also fails when it tries to run the bundle install.
I'd appreciate any help. Cheers.
You can send it wih --build-args
docker build account/image_name:tag --build-arg SSH_PRIVATE_KEY="`cat /opt/atlassian/pipelines/agent/data/id_rsa`"
and the pass it into Dockerfile --> example:
FROM alpine:latest
ARG SSH_PRIVATE_KEY
RUN mkdir /root/.ssh/ && \
apk add --no-cache openssh-client git && \
echo "$SSH_PRIVATE_KEY" | tr -d '\r' > ~/.ssh/id_rsa && \
chmod 600 /root/.ssh/id_rsa && \
cd /your_application_path_in_docker && \
eval "$(ssh-agent -s)" && \
ssh-keyscan bitbucket.org >> ~/.ssh/known_hosts && \
ssh-add ~/.ssh/id_rsa && \
yarn install
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
