Bitbucket Pipeline deployment failed scp: Connection closed
Rika Mandasari
September 11, 2023 edited
I tried to deploy from bitbucket pipeline to one of my VM on GCP
on bitbucket-pipelines.yml, I just do simple SCP from local bitbucket to remote path:
script:
- pipe: atlassian/scp-deploy:1.3.0
variables:
USER: 'my_user'
SERVER: '35.194.xx.xx'
REMOTE_PATH: '/var/www/html/TIS'
LOCAL_PATH: '${BITBUCKET_CLONE_DIR}/*'
SSH_KEY: 'my ssh key which encode to base64'
EXTRA_ARGS: ['-o', 'StrictHostKeyChecking=no']
here's the error:
Load key "/root/.ssh/pipelines_id": error in libcrypto
116
my user@35.194.xx.xx: Permission denied (publickey).
117
118
✖ Deployment failed.
I can clone this repo from the remote path, so I assume there's nothing wrong with my ssh_key
how to fix this?
Thank you in advance
Theodora Boudale
September 12, 2023
Hi Rika,
There was a very similar question about this issue yesterday, perhaps from one of your colleagues?
You can check my reply here:
Theodora
