Bitbucket Pipeline not found even it is exists in main branch.
thanhle97
February 21, 2023
Hi Community,
Hope you guys are doing well :).
I have created a bitbucket-pipelines.yml file and merged it to the main branch of our repository, however the pipeline setting can not detect my yml pipeline and keep require create a new pipeline from the template sample.
Is there any body also counter this problem and figured out the solution for this?
I would be grateful for any tips or helps over here.
Theodora Boudale
February 22, 2023
Hi @thanhle97 and welcome to the community!
If I understand correctly, the bitbucket-pipelines.yml file was initially created in a branch other than the main one?
Can you please try the following steps:
  • Open this repository on Bitbucket Cloud website
  • Select Repository settings (from the left sidebar)
  • On the new sidebar that opens, look for the PIPELINES section and Settings on that section and select that option
  • On the new page that opens, select Enable Pipelines
  • Afterwards, go back and select the Pipelines page of the repo again, you should see the following page that you can use to run the initial pipeline:
Screenshot 2023-02-22 at 11.43.52.png Please feel free to let me know how it goes and if you have any questions!
Theodora
thanhle97
February 26, 2023
Hi @Theodora Boudale ,
Thank you very much for the details in solution. I have following and resolve the issue. Also, the pipeline not triggered due to I was missing indent in my YAML file.
Like 大西 健志 likes this
Stephen Breakey
April 19, 2023
This isnt working for me.
I've toggled the setting multiple times to no avail.
If i go to a specific commit and click run pipeline there, a popup appears with nothing in the drowdown, so i click "see configurations" which links to:
https://bitbucket.org/REDACTED/src/COMMIT_REF/bitbucket-pipelines.yml
but this shows an error. The file is definitely present at the linked commit ref.
Theodora Boudale
April 21, 2023
Hi @Stephen Breakey ,
I would like to ask if you could please create a new question via https://community.atlassian.com/t5/forums/postpage/board-id/bitbucket-questions and we will look into your issue.
It's best to have a separate question for an issue you would like us to troubleshoot, especially when the root cause seems to be different, as a question can become convoluted and difficult to follow if we try to troubleshoot multiple users' issues.
When you create a new question, please provide screenshots of any errors and also the content of your bitbucket-pipelines.yml file. If you don't feel comfortable sharing this here, you can also create a ticket with the support team, which will be visible only to you and Atlassian staff. You can create a ticket via https://support.atlassian.com/contact/#/, in "What can we help you with?" select "Technical issues and bugs" and then Bitbucket Cloud as product.
Theodora
Vincent Maugein
April 10, 2024 edited
If someone's arrives here and is still blocked:
Check there is no space at the beginning of the bitbucket-pipelines.yml filename.
Easy to check in the url:
https://bitbucket.org/org/repo/src/master/%20bitbucket-pipelines.yml
Just in case...
Vincent Maugein
April 10, 2024
Just in case...
Mark Teese
June 18, 2024
How difficult would it be for Atlassian to provide a more useful message in the bitbucket pipeline? Right now, a user:
  • commits a bitbucket-pipelines.yml
  • opens the pull-request and looks too see if the pipeline has run
  • sees a message "It looks like you haven’t configured a build tool yet. You can use Bitbucket Pipelines to build, test and deploy your code. Your existing plan already includes build minutes. Set up a pipeline"
  • clicks on "Set up a pipeline"
  • and then is very confused, because this offers a series of bitbucket-pipelines.yml templates, which the user has already committed.
Here's an alternative logic:
IF branch contains a bitbucket-pipelines.yml, and Enable Pipelines is FALSE, show message "It looks like you haven't enabled pipelines in your repository. To enable, go to repository settings, PIPELINES section, Settings, and Enable Pipelines"
Like Theodora Boudale likes this
Theodora Boudale
June 19, 2024
Hi Mark,
Thank you for the feedback. I understand that this behavior can be confusing to users.
I went ahead and created a request to improve it here:
Theodora
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
