Bitbucket Pipelines and git submodules
Gediminas Å edbaras
July 20, 2016
Hello!
How can I make Pipelines work when my repo contains git submodules that need to be initialized before the build is started?
13 votes
Jacob Ideskog
August 31, 2017
This seems fixed now with the SSH keys available in pipelines.
1. Create an SSH keypair for the repo that runs the pipeline that needs to init a submodule
2. Add the public key to the submodule repo.
3. add `git submodule update --init` to your pipeline script
sofrito
December 27, 2017
Works. Thanks.
Like • mcw likes this
Gijs Wobben March 12, 2018
Works perfectly! Thanks!
tri.nm
It works. Thanks !
As a note, you should remove
$USERNAME:$PASSWORD
from your git path in your git commands inside your pipeline script.
Because only the ssh key is enough for authentication.
Like • 2 people like this
mcw
August 26, 2019
This worked for me as well.
To be clear, add the public key as an Access Key in the `submodule` repo.
Like • Byron Appelt likes this
5 votes
sunnywcwong
April 18, 2017
It surely is a "massive missing feature in BB Pipelines". After 9 months passing by, is this fixed now? or is it still a manual submodule update?
5 votes
romanas667
July 25, 2016
That isn't enough.
If your submodules point at an ssh Bitbucket url (git@bitbucket.org:org/repo.git), you need to change the url of the submodule as well. I did it like this:
git config --file=.gitmodules submodule.$SUBMODULENAME.url https://$USERNAME:$PASSWORD@bitbucket.org/org/repo.git
Then it's the standard git submodule update --init.
This feels like a massive missing feature in BB Pipelines and I hope it gets resolved in future updates!
5 votes
SebC
July 20, 2016
you'll need to reconfigure the git remote to pull from Bitbucket. Pipelines uses an O-auth token to do the initial cloning which is then destroyed immediately afterwards.
First you'll want to create an app-password for the user who's going to access the submodules (App passwords are here in Bitbucket Cloud | Bitbucket Blog). This will ensure you can work with 2fa enabled on the account.
Then you'll need to provide the username and app-password as Bitbucket Pipelines variables (https://confluence.atlassian.com/display/BITBUCKET/Environment+variables+in+Bitbucket+Pipelines)
assuming you've named them USERNAME and PASSWORD, add this step to the start of your pipeline:
git remote set-url origin https://$USERNAME:$PASSWORD@bitbucket.org/team/repo.git
followed by initialising your submodules
kenken17
August 19, 2016
Hi I have tried 20+ times but until the `git submodule update --init` step, it always said:
+ git submodule update --init
Submodule 'dev/scripts/api' (git@bitbucket.org:team/services.git) registered for path 'dev/scripts/api'
Cloning into 'dev/scripts/api'...
Warning: Permanently added 'bitbucket.org' (RSA) to the list of known hosts.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
fatal: clone of 'git@bitbucket.org:team/services.git' into submodule path 'dev/scripts/api' failed
Anyone has experienced this?
Michael Dahlke
April 3, 2017
Did you solve this issue?
I'm running into the same problem :(
NissimPradhan
May 17, 2017
Please note that, the environment variable $USERNAME mentioned by Sebastian should be account username instead of the app password username. The password should be the password from one of the app passwords you've created in account settings.
Thilak Rao
October 27, 2018
Like • Karim Heraud likes this
Mike Medved
I've added SSH keys from the pipeline repo to my submodule bitbucket repos, but I continue to get this error when trying to do a submodule update
fatal: could not read Username for: No such device or address
Seems clearly related, help?
Like • Vinay Kumar likes this
Mike Medved
note that bitbucket.org was up in the fatal line, but Atlassian communities kept barfing on it, even in code or block quote.  Sup with that?
Shawn Chan
June 10, 2021 edited
just spent a whole afternoon looking into this... the answer provided by Jacob Ideskog does work. However, one important point is to make sure the module url in`.gitmodules` is something like git@bitbucket.org:XXXX but not using https:. Only when it's set toSSH it will pick up the public key you generated and added to the submodule's repo. Otherwise, it will complain about either the username or password cannot be found.
Hope this helps
Yashvit November 13, 2019
I followed the steps shown on this: https://confluence.atlassian.com/bitbucket/use-ssh-keys-in-bitbucket-pipelines-847452940.html
Managed to get the git submodule checkout working fine.
Only issue is, we use IP Whitelisting for our Bitbucket Account. When that is enabled, the submodule checkout fails!
Warning: Permanently added the RSA host key for IP address '18.205.93.0' to the list of known hosts.
To access this repository, an admin must whitelist your IP.
I tried whitelisting this IP and a bunch of others that it uses, but no luck!
Anyone has managed to get a workaround for this?
Carl Cook
June 6, 2022
Same problem here. Did you have any luck fixing the problem? I'll raise a ticket otherwise.
Soeren Balko
August 14, 2017
Atlassian, this needs urgent fixing! I thought the advantage of using Bitbucket pipelines over some external CI system was the better integration with Bitbucket. Turns out that's not the case. Sad!
Simon February 10, 2020
Hi
I would also like to use a submodule in my pipeline.
The submodule has been initilaised, but unfortunately
fails with the error:
fatal: destination path '<pathToSubmodule>' already exists and is not an empty directory,
because during the build setup the node_modules were already loaded from the cache.
Is there a solution for this?
Valerii Kulyk, Mindk.com
May 12, 2020
use git submodule update --init --force
Simon December 1, 2020
Hi @Valerii Kulyk, Mindk.com
thanks for you answer, but this is not working. I still get the same error.
The --force option only causes the submodule to be cloned with git checkout --force, but does not fix the error that the submodule's folder is not empty.
Brian Maissy
For anyone else who found this thead and thinks this is a serious oversight, you can vote on the issue here https://bitbucket.org/site/master/issues/12853/private-submodule-support
