Hello Bitbucket.
My team is currently using the atlassian/aws-lambda-deploy image for lambda deployment.
Our lambda functions deploy but the default directory/filepath does not allow our Lambda function to run correctly. Can we change the lambda deploy function to copy only to the root directory?
/opt/atlassian/pipelines/agent/build/aws_lambda/workspace_getactivations/workspace_getactivations.py
to
This is the relevant snippet from the bitbucket-pipelines.yml we are using:
@Nicolas Hunter hi. Thanks for your question.
Check this answer, is this your case?
Regards, Igor.
