I can't find conclusive info on whether Smart Mirroring is included with a Bitbucket Data Center license, or is a Premium Feature that requires an additional fee.
Does anyone know?
Jozef
Hi Jozef,
Smart mirroring is included with Bitbucket Data Center. If you have Bitbucket Cloud, it's available as part of the Premium account.
For reference, please see Set up a mirror.
Hope that helps!
Ana
Thanks. That clears it up. Another item I find conflicting info for is whether code can be pushed to the mirror, or has to be pushed to the primary Bitbucket instance.
In below article, the diagram indicates the remote developers can only clone and fetch code from the mirror. However, in the text it says:
"Once I've cloned from a mirror, am I supposed to push to the mirror as well?
Yes, you can push to the repository using the same URL, and Bitbucket relays the push to the upstream repository."
https://confluence.atlassian.com/bitbucketserver/smart-mirroring-776640046.html
Which is it? :)
Jozef
Never mind. That question has been asked before. It appears the text is correct and the diagram is wrong:
