Could you please help me with the following questions regarding LFS support in Bitbucket :
Best,
G.
Hi G.,
The 100 MB limit is not enforced if you push to an empty Bitbucket Cloud repo with no commits.
Additionally, it is possible to disable the limit (if you are a repo admin) from Repository settings > Repository details > select ADVANCED > uncheck the option Block pushes with files over 100MB.
You mentioned that cloning speed is not a conecrn for you. Please keep in mind that apart from cloning speed, multiple large files also contribute to the repository size. Every Bitbucket Cloud repo has a limit of 4 GB. If a repo exceeds this limit, it will become read-only and you won't be able to push any changes.
The extra storage of 100 GB for $10/Month is only for LFS, and not for the core Git repo.
If you want to track with LFS files that are already committed to a repo, then a history rewrite is necessary.
Please feel free to reach out if you have any other questions!
Theodora
Thank you @Theodora Boudale !
May I ask a follow up question: Is the 4GB limit per repository? Is there a limit on how big the a Bitbucket Workspace can be (Is there a limit of the total size of all the repositories under an account) ?
Best,
G.
You are very welcome, G.!
The 4 GB limit is per repository. We don't have a limit on the total size of all repos under a workspace.
Please feel free to let me know if you need anything further.
Theodora
@G_ W_ Welcome you might take a look at this link: https://support.atlassian.com/bitbucket-cloud/docs/manage-large-files-with-git-large-file-storage-lfs/
HTH
Nicolas
Hi Nicolas,
Thank you for your reply. Could I ask you a follow up question:
Thank you again!
G.
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
