Bitbucket extension in VSCode
marcusobrien
January 18, 2024 edited
Is the only way to commit changes to a Bitbucket repo before pushing them from the VS code IDE, to use the in built commit feature in VS Code or the VS code Terminal/command line or can I setup the Bitbucket extension to do it also ?
Theodora Boudale
January 23, 2024
Hi Marcus,
It is not possible to commit with Atlassian for VS Code extension. You can check the documentation below about what functionalities are available:
If you want to commit from VS Code, you will need to use VS Code's built-in commit feature or the integrated terminal.
Theodora
