Bitbucket has unexpected behaviour with masked variables
Kimberling Yarihuaman January 31, 2025 edited
Hi!
Bitbucket has unexpected behaviour when I use masked variables. The pipeline logs show the variable names. I attached some screenshots.
- Pipeline logs with masked variable
- Masked variable into Repository Variables. The variable value is 1
Can you help me with this issue?
Thans in advance.
Ben
February 3, 2025
Hi @Kimberling Yarihuaman
This is by design. Secure variables are supposed to be secret and not exposed (for example: tokens/app passwords/ssh keys/passwords).
If you wish to see the value of that variable exposed in your build logs, you'll need to add it as a non-secured variable.
Cheers!
- Ben (Bitbucket Cloud Support)
Kimberling Yarihuaman February 7, 2025 edited
Hi Ben!
I understand you, but my doubt is why the variable name is shown in logs if those datas shouldn´t be replaced by variables. For example, the following texts should only show the quantity failed and passed tests, not the variable name, because they are not related to that.
If you need more information, please let me know.
Cheers!
Ben
February 9, 2025
Hi Kimberling,
Pipelines has no way of knowing if the data in your secured variable is related to the values in your tests.
It simply checks to see if any values in the output match secured variables and masks them to prevent exposure of these secured variables in the build logs.
If you store "1" as an unsecured variable - you won't see this problem anymore.
Cheers!
Kimberling Yarihuaman February 12, 2025
Hi Ben!
Thanks so much.
Cheers!
