I have a bitbucket pipeline and there are many steps in pipeline , I am getting error of "docker memory exceed" as it is build trigger, I tried many combination of memory in the definition section of bitbucket pipeline but issue is not resolved. i can share my pipeline ,
Hello @manish_taazaa
thank you for reaching out to Community!
Could you please confirm what exact error message you are receiving in the UI?
I ask this because the troubleshooting steps are different in cases where the Build container or the Docker service container is running out of memory.
The Build container is where your step's script is executed. The Docker service is where your docker commands (such as docker build) are executed.
We have the following troubleshooting guides for each of the cases that may be of help :
If after following those instructions you are still receiving the error, we kindly ask you to share the exact error message and also the pipeline YAML so we can assist you further.
Thank you, @manish_taazaa !
Patrik S
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
