Bitbucket pipeline endpoint is not filtering data based on created_on filter.
Akash Litoriya
August 28, 2025
I want to filter out the pipelines based on `created_on` field, but the api is returning all the pipelines instead of filtered out pipelines. I'm attaching the curl I'm using to fetch the filtered pipelines.
curl --location --globoff "https://api.bitbucket.org/2.0/repositories/<workspace>/<repo>/pipelines/?q=created_on>=\"2025-08-29T00:00:00\""
Saxea _Flowie_
August 28, 2025
I'm afraid this is a know bug/limitation. See BCLOUD-14000.
Akriti Sagar
August 28, 2025
Hi @Akash Litoriya,
The issue is with the query syntax in your API call. The Bitbucket 2.0 API requires filters to be wrapped in URL-encoded query strings. Your > and = operators need to be encoded, otherwise the API just ignores the filter.
Try this instead:
curl --location --globoff \
"https://api.bitbucket.org/2.0/repositories/<workspace>/<repo>/pipelines/?q=created_on%3E%3D%222025-08-29T00:00:00%22"
Here’s what changed:
  • > becomes %3E
  • = becomes %3D
  • Quotes around the timestamp are required and must be URL-encoded (%22).
This should correctly return only pipelines created on or after 2025-08-29T00:00:00.
If you still see unfiltered results, double-check that your repo actually has pipelines with created_on values after that date, since the filter won’t apply if there are none.
Akash Litoriya
August 28, 2025
I tried the provided curl, still not getting the filtered data. There are pipeline in repository that are created after the date provided in the filter still getting all the pipelines in the response.
Saxea _Flowie_
August 28, 2025
edit: posted as top level answer.
