Bitbucket pipeline using ssh setup issue
venkatcss October 20, 2019
Hi Team,
This is Venkat, I was already setup the bitbucket pipeline using ssh that is working fine , now i want to add the one more folder under the pipeline can you please guide me.
My bitbuket repository folder structure I gave. please find the attachment.
I have setup the pipeline for admin folder.
NOw i want to add the Mobile_API_setup folder under this pipeline and I want to deploy those code under path  (api.ydtwebstaging.com) on server.
My pipeline setup configuration file is bitbucket_pipeline.yml
image: ubuntu:16.04
pipelines:
branches:
Ydtwebstaging:
- step:
script:
- apt-get update -y
- apt-get install -y zip
- apt-get install php libapache2-mod-php -y
- apt-get install curl -y
- cd admin/back-end
- zip -r artifact.zip *
- apt-get install sshpass -y
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact.zip username@ip:/home/ydtwebstaging/deploy
- step:
image: node:10.15.0
script:
- apt-get update -y
- cd admin/front-end
- npm install
- CI=false
- npm run build
- zip -r artifact1.zip *
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact1.zip username@ip:/home/ydtwebstaging/deploy
under this configuration i want to zip Mobile_API_setup folder also
Can you please guide me
Venkat
Hi Team,
For this issue I have tried with following configuration file but I am getting the error alt last step.
image: ubuntu:16.04
pipelines:
branches:
Ydtwebstaging:
- step:
script:
- apt-get update -y
- cd Mobile_API_Setup
- zip -r artifactapi.zip *
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifactapi.zip username@ip:/home/ydtwebstaging/deploy
- step:
script:
- apt-get update -y
- cd admin/back-end
- step:
image: node:10.15.0
script:
- apt-get update -y
- npm install
- CI=false
- npm run build
- time sshpass -p 'passowrd' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact1.zip username@ip:/home/ydtwebstaging/deploy
The error i am getting :-
Build failed link
https://bitbucket.org/ydtmeldev/ocs_admin/addon/pipelines/home#!/results/1525
Regards:
Venkat
venkatcss October 21, 2019
Hi Team,
It;'s got resolved  I have fixed issue
Venkat
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
