Bitbucket pipelines does not substitutes deployment variables in all places.
Shoaib Khan June 20, 2022
When I'm running my pipelines, all the deployment variables show up when I use "env" command this includes the namespace which I'm passing as ${OC_PROJECT}. But later in same script when I use it during deployment, its value doesn't get populated there. Because of which I'm getting errors during deployments.
helm upgrade -n ${OC_PROJECT} -i -f charts-config/.........3.JPG 1.JPG
Patrik S
June 21, 2022
Hello @Shoaib Khan ,
Thank you for reaching out to Atlassian Community.
In order for us to investigate further, could you please share the bitbucket-pipelines.yml file of your build?
Also, from the screenshot, it seems you are executing a script file inside your build. If that is the case, could you also share the section from the script where you are referencing the variable? Have you tried referencing the env variable with $OC_PROJECT instead of ${OC_PROJECT}?
Patrik S
