×Dear all,
The Bitbucket Pipelines schema at api.bitbucket.org/schemas/pipelines-configuration does not include parent/child pipelines yet, so pipeline configs using that feature fail schema validation (for example, when using VS Code atlascode plugin, but we also do custom schema validation using the public schema)
Can the schema be updated? And can it be kept up-to-date?
Thanks in advance,
Best regards,
Casper
