We are using a local jenkins CI server in which pull requests builds are triggered using the Bitbucket Pull Requests Builder plugin.
When a build succeeds, the PR gets approved by the jenkins user, which is fine.
But when a build fails, I'd like to prevent developers from merging the PR, but I didn't find how to do that.
The closest I could find was to create a branch permission with Check for at least 1 approval from default reviewers, then set the jenkins user as a default reviewer for the project and check Prevent a merge with unresolved merge checks.
But if I do that:
Does anyone know of a solution for that?
