I would like to write a script and/or golang program that can access the bitbucket cloud repo and modify the permission to
- add one or more user to the Merge via pull request option
- remove one or more user from the Merge via pull request option
- allow Write Access to a branch for one or more user
Am sure some api's exist and would appreciate if someone points me to the right path.
Hi @Jayaraj Wilson,
Here is the REST API documentation for BitBucket Cloud, specifically looking at a pullrequest by id:
I hope that's what you were looking to find.
-Jimmy
Hello @Jayaraj Wilson ,
Here's the endpoint to create branch permission, and here's the one to modify an existing one.
All three use cases you described refer to updating a branch restriction, so the latter endpoint is what you're looking for.
Hope this helps.
Daniil
