My previous email was : mahade.hasan68@gmail.com
Then i changed to mahade@quester.io
after that all my repo are not sync with local. i am not able to clone, push etc.
Than i tried to change the user name but after changing my user name still not working.
i can login to my account via browser with new email but can not login with new username
Welcome to the Community!!
If you are able to access the repo in the Browser, you will have to remove the existing credentials in the system and authenticate again in order to clone the repositories.
Can you try the below steps and let me know if it worked
Pramodh
I have generate app password
with this password now repository are syncing.
thanks
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
