Hello!
I've stumble accross a problem, where I've installed a free Bibucket App for my organization and created a new organization. Interestingly enough, I can't access this new workspace. Now I've found this issue https://jira.atlassian.com/browse/BCLOUD-23018 which kinda describes my problem, but the proposed workaround doesn't work. Navigating to https://bitbucket.org/account/workspaces/ doesn't list my new workspace.
I tried creating an API TOKEN and use rest api to try and add a project/repository/grant the proper permissions to my user, but this didn't work either, since the API TOKEN generated didn't seem to do the trick (simple api token, or even base64 token. Tried various ways).
I'm an org admin and my user has access both as admin and as user on bb.
Alex
Hmm.. It looks another mystery Repository not Found problem similar to this..
So there is a KB article but id does not cleary says what is the main problem
I guess someone from Atlassian like @Theodora Boudale should look at this specific case also..
Hi @Mirek
Thanx for your reply. I posted the question since it's a free BB instance, with the hope that someone from Atlassian will see this. And there's a specia tag we add to such thread, but can't recall it.. :/
