Can't access unsecured variable in pipelines script
Chris Thorp June 14, 2022
I'm trying to access a variable (unsecured) in a script to create a .env file before building, but the file is always created empty. The plan is to base64 decode it, but right now I'm just trying to access it at all. As far as I can read only secured variables should be restricted. What am I missing?
Screenshots below
script:
- echo $ENV_FILE > .env.local
- cat .env.local
- yarn install
- yarn build
 Monosnap rushhourmedia _ wristcheck-next _ Deployments — Bitbucket 2022-06-14 17-54-24.pngMonosnap rushhourmedia _ wristcheck-next — Bitbucket 2022-06-14 17-55-20.png
Norbert Csupka
June 15, 2022
Hi Chris,
Thanks for reaching out to Atlassian Community, my name is Norbert and I'm a Bitbucket Cloud Support Engineer, it's nice to meet with you!
This sounds interesting, can you try to do only the "echo $ENV_FILE" command and let me know whether if it shows the environmental variable? Also, can you let me know if you're using Runners or are you running it on our Pipelines infrastructure?
Please let me know.
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
Chris Thorp June 16, 2022
Hi Norbert,
I figured it out myself eventually - this was a deployment level variable which I didn't realise would not be available in non-deployment steps. I have moved it to a repository level variable which is now working.
Thanks for he reply
Norbert Csupka
June 16, 2022
Hi Chris,
Thank you for your reply, I'm glad to hear your issue is resolved :).
Have a lovely weekend ahead and stay safe!
Best Regards,
Norbert
