Can you share running containers between steps?
Xavier Serrat Bordas September 5, 2022
Hi!
I have a pipeline where we're running different docker containers connected to each other using docker-compose.
I'm wondering if we have a way to share the running containers between steps to run some tests in parallel.
Is it possible?
Thanks in advance!
Xavier.
Patrik S
September 6, 2022
Hello @Xavier Serrat Bordas ,
As each step in the pipelines runs in a isolated environment (each step in its own container), I'm afraid it's not possible to share the containers you start in a given step with the other steps.
In this case, if you would like to use parallel steps as part of your build, you would have to spin up the docker-compose containers in each of the parallel steps separately.
Let me know in case you have any questions.
Thank you, @Xavier Serrat Bordas .
Patrik S
Xavier Serrat Bordas September 7, 2022
Hello Patrik,
Perfect, thanks for your reply.
