I want to display and lock a different branch to pull in Sourcetree. It always shows me up default as master branch and i want the developers to get UAT branch as the default remote branch to pull as in option in sourcetree.
Hi @Bhavin Sanghvi, Here what does mean lock a different branch.
If you mean to switch to a different branch in the Sourcetree, just click on your branch in the left side tab and choose Checkout or just double click on the branch to check out. Then you can use pull to get updates from remote branches.
Ram.
