Checkout in sourcetree not working after upgrade to v3.x
Eric Constantinides
October 26, 2018
After upgrading to v3.0, "Checkout in SourceTree" no longer works. All that happens is that it'll bring up the SourceTree App, but do nothing else.
I am downgrading to v2.7.4 until this is resolved.
I'm on a Mac running MacOS Mojave 10.14.
Any possible fix for this? I noticed the same exact issue came up when upgrading to 2.x (https://community.atlassian.com/t5/Bitbucket-questions/Checkout-in-sourcetree-not-working-after-upgrade-to-v2-x/qaq-p/587309).
Mark Boessenkool
November 1, 2018
Also an confirmation from my end.
However with the extra information that I have MacOs High Sierra 10.13.6.
Sourcetree v3.0 (200)
marcocarosi December 23, 2018
With the 3.1 Beta (208), uploaded on Dec 20th, the issue is finally fixed!
You can download the SourceTree latest beta versions here: https://bitbucket.org/atlassianlabs/sourcetree-betas/downloads
ilyasnow
December 25, 2018
Asusual Not working
marcocarosi December 26, 2018
I am on Bitbucket server v5.7.1, it works for me there.
HA
January 3, 2019
works for me too.  Thanks!
marcocarosi October 29, 2018 edited
(sorry, not an answer, just a confirmation of the problem)
Same OS version, same problem, I had to downgrade to 2.7.4 as well.
The link opens SourceTree but nothing happens after that.
I tried manually to create a URI schema (I followed some examples found in the internet, like https://gist.github.com/equinox79/7212950), but again same issue: it opens SourceTree but does nothing else.
Karthick_Selvaraj
April 10, 2019
I'm facing this in Sourcetree version, 3.0.1. Any solution for this issue?
Nathan November 26, 2018
Any resolution on this issue? I'm seeing it as well. 3.0.1 on 10.14
