×Hello guys,
I need to install several docker dependencies for composer with my pipeline but I'm getting the errors below:
+ composer install
Installing dependencies from lock file (including require-dev)
Verifying lock file contents can be installed on current platform.
Your lock file does not contain a compatible set of packages. Please run composer update.
- Root composer.json requires PHP extension ext-amqp * but it is missing from your system. Install or enable PHP's amqp extension.
Problem 2
- Root composer.json requires PHP extension ext-bcmath * but it is missing from your system. Install or enable PHP's bcmath extension.
Problem 3
- php-amqplib/php-amqplib is locked to version v3.6.2 and an update of this package was not requested.
- php-amqplib/php-amqplib v3.6.2 requires ext-sockets * -> it is missing from your system. Install or enable PHP's sockets extension.
Problem 4
- php-amqplib/rabbitmq-bundle 2.16.0 requires php-amqplib/php-amqplib ^2.12.2|^3.0 -> satisfiable by php-amqplib/php-amqplib[v3.6.2].
- php-amqplib/rabbitmq-bundle is locked to version 2.16.0 and an update of this package was not requested.
To enable extensions, verify that they are enabled in your .ini files:
- /usr/local/etc/php/conf.d/docker-fpm.ini
- /usr/local/etc/php/conf.d/docker-php-ext-sodium.ini
You can also run `php --ini` in a terminal to see which files are used by PHP in CLI mode.
Alternatively, you can run Composer with `--ignore-platform-req=ext-amqp --ignore-platform-req=ext-bcmath --ignore-platform-req=ext-sockets` to temporarily ignore these required extensions.
I use php:8.2.20-fpm-bullseye because there is php 8.2 support. What I did so far is to try the installation with:
apt install php8.2-amqp
Hi Ivo and welcome to the community!
Pipelines builds run in Docker containers. For every step of your build, a Docker container starts (the build container) using the image you have specified in your bitbucket-pipelines.yml file. The repo is cloned in this container, and then the commands of the step's script are executed.
Since you are using php:8.2.20-fpm-bullseye, the Docker container where your build runs uses the following Dockerhub image:
This Docker image is based on Debian 11 (bullseye), so the question is how you install these extensions in a Docker container that uses Debian 11.
I suggest reaching out to a PHP-specific forum for help with how to install these extensions in Debian 11.
You can then debug your pipeline locally using the following guide:
When you have a command and build that works locally following this guide, it should work in Pipelines as well.
Theodora
