Composer not installing web/core or web/modules/contrib in Drupal project
Chris Thorp February 23, 2024 edited
This bitbucket-pipelines.yml file has worked for year, but has suddenly broken with no changes. composer install works perfectly on local machine, and on server, just not in pipeline. Has something changed?
'web/core' 'web/modules/contrib' not created, although 'vendor' is, how can I fix this?
Logs from the pipeline:
Searching for files matching artifact pattern vendor/**
Artifact pattern vendor/** matched 30513 files with a total size of 131.4 MiB
Compressed files matching artifact pattern vendor/** to 38.1 MiB in 13 seconds
Uploading artifact of 38.1 MiB
Successfully uploaded artifact in 2 seconds
Searching for files matching artifact pattern web/core/**
Searching for files matching artifact pattern web/modules/contrib/**
Searching for files matching artifact pattern web/themes/rhm_starter/css/build/**
Artifact pattern web/themes/rhm_starter/css/build/** matched 1 files with a total size of 3.2 MiB
Compressed files matching artifact pattern web/themes/rhm_starter/css/build/** to 513.5 KiB in 1 seconds
Uploading artifact of 513.5 KiB
Successfully uploaded artifact in 0 seconds
# This is a sample build configuration for PHP.
# Check our guides at https://confluence.atlassian.com/x/e8YWN for more examples.
# Only use spaces to indent your .yml configuration.
# You can specify a custom docker image from Docker Hub as your build environment.
image: drupal:8
definitions:
caches:
node-custom: web/themes/me/node_modules
steps:
- step: &Build-step
caches:
- composer
- node
- node-custom
script:
- apt-get update && apt-get install -y unzip
- apt-get install -y unzip git
- apt-get install -y libxml2-dev php-soap && apt-get clean -y && docker-php-ext-install soap
- curl -sL https://deb.nodesource.com/setup_12.x | bash -
- curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.35.3/install.sh | bash
- apt-get install -y nodejs
- npm install -g gulp
- curl -sS https://getcomposer.org/installer | php -- --install-dir=/usr/local/bin --filename=composer
- composer install --ignore-platform-reqs
- cd web/themes/me/.gulp
- npm install
- gulp buildStyles
- gulp buildScriptsMin
artifacts:
- vendor/**
- web/core/**
- web/modules/contrib/**
- web/themes/me/css/build/**
- web/themes/me/js/build/**
- step: &Deploy-step
script:
- pipe: atlassian/rsync-deploy:0.4.3
variables:
USER: $USER
SERVER: $SERVER
REMOTE_PATH: $REMOTE_PATH
LOCAL_PATH: '.'
EXTRA_ARGS: '--exclude-from=deployment-exclude-list.txt'
- pipe: atlassian/ssh-run:0.2.6
variables:
SSH_USER: $USER
SERVER: $SERVER
COMMAND: "cd $REMOTE_PATH/web && export PATH=/RunCloud/Packages/php81rc/bin:$PATH:$HOME/bin && ../vendor/drush/drush/drush cr && ../vendor/drush/drush/drush updb -y && ../vendor/drush/drush/drush cim -y"
pipelines:
branches:
development:
- step: *Build-step
- step:
<<: *Deploy-step
deployment: test
staging:
- step: *Build-step
- step:
<<: *Deploy-step
deployment: staging
master:
- step: *Build-step
- step:
trigger: manual
<<: *Deploy-step
deployment: production
composer.json:
"name": "drupal-composer/drupal-project",
"description": "Project template for Drupal 8 projects with composer",
"type": "project",
"license": "GPL-2.0-or-later",
"authors": [
"name": "",
"role": ""
"repositories": [
"type": "composer",
"url": "https://packages.drupal.org/8"
"require": {
"ext-json": "*",
"composer/installers": "^1",
"cweagans/composer-patches": "^1.6.5",
"drupal/admin_toolbar": "^3",
"drupal/advagg": "^5",
"drupal/amswap": "^3",
"drupal/anonymous_login": "^2",
"drupal/better_exposed_filters": "^6",
"drupal/captcha": "1.x-dev",
"drupal/console": "~1.0",
"drupal/copyright_block": "^2",
"drupal/core-composer-scaffold": "^9",
"drupal/core-recommended": "^9",
"drupal/date_popup": "^1.0",
"drupal/devel": "^5",
"drupal/devel_php": "^1.1",
"drupal/disable_language": "^1.0",
"drupal/eck": "^1.0@alpha",
"drupal/entity_browser": "^2.2",
"drupal/field_encrypt": "^2",
"drupal/field_group": "^3",
"drupal/google_analytics": "^4.0",
"drupal/mailchimp": "^2",
"drupal/menu_item_extras": "^2.4",
"drupal/metatag": "^1.8",
"drupal/mimemail": "^1.0@alpha",
"drupal/paragraphs": "^1.7",
"drupal/partial": "^1.1",
"drupal/pathauto": "^1.3",
"drupal/prepopulate": "^2.2",
"drupal/quick_node_clone": "^1.12",
"drupal/rabbit_hole": "^1.0@beta",
"drupal/real_aes": "^2.2",
"drupal/recaptcha": "^3",
"drupal/recreate_block_content": "^3",
"drupal/reroute_email": "^2",
"drupal/rules": "3.x-dev@dev",
"drupal/site_settings": "^1.13",
"drupal/stage_file_proxy": "^2",
"drupal/stripe": "^1.0@beta",
"drupal/swiftmailer": "^2",
"drupal/time_range": "^9",
"drupal/twig_extensions": "2.x-dev@dev",
"drupal/twig_tweak": "^3",
"drupal/ultimate_cron": "^2.0@alpha",
"drupal/verf": "^2",
"drupal/views_conditional": "^1.0",
"drupal/views_data_export": "^1.0@beta",
"drupal/xmlsitemap": "^1.0@alpha",
"drupal/youtube": "^2",
"drush/drush": "^10",
"vlucas/phpdotenv": "^2.4",
"webflo/drupal-finder": "^1.0.0",
"webmozart/path-util": "^2.3"
"require-dev": {
"drupal/twig_xdebug": "^1.0"
"conflict": {
"drupal/drupal": "*"
"minimum-stability": "dev",
"prefer-stable": true,
"config": {
"sort-packages": true,
"allow-plugins": {
"cweagans/composer-patches": true,
"composer/installers": true,
"drupal/core-composer-scaffold": true,
"drupal/console-extend-plugin": true
"autoload": {
"classmap": [
"scripts/composer/ScriptHandler.php"
"files": [
"load.environment.php"
"scripts": {
"pre-install-cmd": [
"DrupalProject\\composer\\ScriptHandler::checkComposerVersion"
"pre-update-cmd": [
"post-install-cmd": [
"DrupalProject\\composer\\ScriptHandler::createRequiredFiles"
"post-update-cmd": [
"extra": {
"patchLevel": {
"drupal/core": "-p2"
"installer-paths": {
"web/core": [
"type:drupal-core"
"web/libraries/{$name}": [
"type:drupal-library"
"web/modules/contrib/{$name}": [
"type:drupal-module"
"web/profiles/contrib/{$name}": [
"type:drupal-profile"
"web/themes/contrib/{$name}": [
"type:drupal-theme"
"drush/Commands/{$name}": [
"type:drupal-drush"
"drupal-scaffold": {
"locations": {
"web-root": "web/"
"patches": {
"drupal/copyright_block": {
"Fix core version": "https://www.drupal.org/files/issues/2023-05-08/copyright_block-fix-core-version-3357937.patch"
Chris Thorp February 25, 2024
This fixed it at the start of the build script:
- export COMPOSER_ALLOW_SUPERUSER=1
