Confusion of repo name between index page and home page and jira automation
Josh Bouganim
May 16, 2025 edited
In the BB list repo page:
https://bitbucket.org/<org-id>/workspace/repositories/
the repo names are listed as their slugs even though the repo names might have upper case letters (or other non-url friendly characters). The real repo name is only displayed on the repo home page.
This screwed up my jira automation because the jira docs specify {{repository.name}} which i pulled from the index page when drafting the automation. my automation kept failing and it took me a while to figure out that jira needs real repo name with the upper case letters.
this is very confusing.
couple suggestions:
  • {{repository.name}} should use the repo slug (like all other apis) or add {{repository.slug}}
    • update the docs
  • bitbucket should display the real repo name on the index page
i tried to fix my automation by making the repo name all lower case via the repo details menu and i got an error:
Please fix errors below
Default landing page needs your attention
Similar but actually opposite to this post: https://community.atlassian.com/forums/Bitbucket-questions/Unable-to-start-pipeline-using-atlassian-trigger-pipeline-5-1-0/qaq-p/2329424
Patrik S
May 20, 2025
Hey @Josh Bouganim ,
welcome to the Community!
I see you have opened an internal ticket with Bitbucket Cloud support related to this issue. I suggest focusing the discussion on the support ticket to avoid any confusion that may arise from discussing the same issue in multiple places.
Once the ticket is closed, feel free to share the solution here for other community users who may encounter the same questions.
Thank you, @Josh Bouganim !
Patrik S
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
