×Hi everyone,
firstly, thank you for offering a great solution with bitbucket.
I'm very new git/Bitbucket and still sorting things.
My question:
Is it possible to connect my bitbucket versions/account to my webspace (subdomain and domain) ?
My logic says that developing with a versioning tool and then publishing the website by hand is not the correct way.
I have a domain and a subdomain. Of course I'm developing on the subdomain, and when I'm finished I want to publish/redirect/deploy (or whatever it is called) to my main domain.
I've seen that it is possible to host a statis website on bitbucket, but thats not what I want, since I'm using PHP/MYSQLI and JS.
Also I've tried to set the cname record in my domain panel to accountname.bitbucket.org. but it ends up with a 404 error.
I would highly appreciate if someone could point me in the right direction, since this bitbucket service turns out to be the best finding of last couple of years :D
Thank you for any hints
Best Regards
Toby
Excerpt from our documentation:
You may have multiple projects that you want to host from the same Bitbucket websites, you can do this by placing each project in a repository subdirectory. In this example, you would want to organize things such that you can point users to:
•http://accountname.bitbucket.org/subdir1forproject1
•http://accountname.bitbucket.org/subdir2forproject2
•http://accountname.bitbucket.org/subdir3forproject3
Each project sub-sirectory would act as a self-contained website with its own index.html.
Bitbucket is forgiving with regard to trailing slashes: a request to http://accountname.bitbucket.org/projectX/ with result inprojectX/index.html being served (if such a file exists), regardless of whether the trailing slash is included in the URL.
Full details available here:
https://confluence.atlassian.com/display/BITBUCKET/Publishing+a+Website+on+Bitbucket
Hi Jason, thank you for your answer. Unfortunately I'm not lacking of resources.. I'm looking forward to control the different versions of my website with bb/git. Not simply host a static website.
Please correct me if I'm wrong here:
Develop Project on local machine >> push to bb/repo >> and then??? It sits on some webspace.. How can I deploy it when I'm finished.
It's wrong to put all effort in some version control and then publish it by pushing it MANUALLY on MY FTP - isn't it?
Best Redards
Toby
